But...No worries, you'll be able to do both of those things in future updates.
I know, I know... when???
No dates set yet
See the chart above. Demonstrates my point exactly. For example you need to sit closer than 5ft from a 50" 4k TV to have same benefit as sitting 7.5 ft away from a 1080 screen. Who sits closer than 5 feet from a TV? 1080 is every bit as good from normal viewing distances. Don't fall into the trap of believing the hype when that hype comes from someone who wants to sell you something!
The initial report that the Advanced was not compatible with the SDK were a misunderstanding.There is a lot more then just the camera difference between the two, P3A is not SDK compatible
I don't think 4k with the phantom has 4 times more color data... Where did you read this? I would probably say 1080p would hold more data per pixel than 4K, as there are only 2million pixels as opposed to 8million, so the 60mbps data rate would be given to fewer pixels resulting in more info for each pixel? Higher resolution means nothing without the data rate behind it, or 8bit, 10bit color 4:2:0, 4:2:2.I do have a 4k 55" monitor I use for editing video, but I have no desire at this time to upgrade the TV to 4K. That said, if you are doing video, the 4K has 4 times more color data and will result in a much better 1080P video when played at 1080P or compressed down in post processing. 4K is harder to work with, but the quality of the finished video, even at 1080P is definitely better. Reference the video above for why 4K video at 1080P has better color data than 1080P video at 1080P.
If you are just doing still pictures, they are probably identical.
Absolutely no need for 4k camera. A totally over hyped technology that you can't begin to appreciate unless you have a massive 60in plus tv
There is no mention of the advanced in SDK dev page http://dev.dji.com/The initial report that the Advanced was not compatible with the SDK were a misunderstanding.
DJI has confirmed the SDK applies equally to both P3s.
Here's the Phantom 3 project manager confirming it ...There is no mention of the advanced in SDK dev page http://dev.dji.com/
No dates set yet
60 inch is massive? My current 65 disagrees and my viewing distance is about 12 feet. I'm going to shoot for 75 inch next year and it will be 4k, so I'll already have a camera filming for it.Absolutely no need for 4k camera. A totally over hyped technology that you can't begin to appreciate unless you have a massive 60in plus tv
...and Beta was a better machine than the VHS, but the punters have spoken and the P3P wins.Absolutely no need for 4k camera. A totally over hyped technology that you can't begin to appreciate unless you have a massive 60in plus tv
Wrong use of the quote button on my end, sorryI didn't make this point.
I said it [SDK, LS] will be forthcoming.
Thanks!Absolutely no appreciation for a device you don't have.
