N017RW said:Nidge said:To the OP, ecofrone, check your frame configuration in the flight assistant software. There are two quad configurations for a quad, "X" config and "+" config. If you have inadvertently set the Phantom to the "+" config it will exhibit the symptoms you are describing.
Regards
Nidge
Did'nt think the Phantom Naza will allow that. :?
I know the FC's in the later Phantoms are different from those found in the V1's (Naza M) but not by how much. If the assistant software for the later Phantoms doesn't permit the change of airframe configuration then feel free to file my first post under Science Fiction
Regards
Nidge
