- Joined
- Oct 30, 2014
- Messages
- 32,182
- Reaction score
- 10,931
- Location
- Harrisburg, PA (US)
- Website
- phantomhelp.com
It's surely not the cheapest option, but it's supported by DJI and will not void the battery warranty if something happens to it while charging. Those things are important to some peopleI think I'll just stick with my 300W inverter and use my normal charger for half the price
It's surely not the cheapest option, but it's supported by DJI and will not void the battery warranty if something happens to it while charging. Those things are important to some people![]()
I don't think it would. I was referring to using a non-OEM car charger -- like this one.Why would using an inverter with the regular charger void a warranty?
I was attempting to quote him on the price mentionOK, was just confused when you quoted sneekypete who mentioned he was just going to use his normal charger on his inverter.
I've said this in other posts, but I will say again here: A direct car charger is a significantly more efficient, less complicated, less expensive (unless it is DJI's) and potentially less damaging solution, than using the combination of an inverter and the wall charger.
Why is that? Because a direct car charger only needs to transform and regulate the voltage - from 12.x to 17.x volts DC. That is easy and cheap to do. An inverter must not only do the transform from 12v to 110v, but it must invert the power from DC to AC. Most inexpensive inverters do this by creating a square wave, or a modified sine wave, rather than the smooth, 60hz sine wave that virtually all modern US utilities provide. Why does this matter? Because consumer electronics have been known to be damaged by crappy inverted AC. Would that happen to you? Probably not - battery chargers are fairly resilient devices - but why do it in the first place?
An inverter solution also requires that the power be converted a second time, from 110v AC down to 17.x volts DC. Each of these conversions is inefficient.
As for the DJI car charger... I am sure it is well made, and it comes with a way to charge the RC. But $85??? Ugh. You can buy a car charger from Amazon for less than $20 and it will do just fine. I have been using one for a while and have experienced no problems with it; I will note that it takes about 90 minutes to recharge the Phantom 3 battery. It is a life saver when you are in the middle of nowhere and need just one more flight to finish a project. And you can do 10 or 15 flights, at least, on a single charge of the RC, so the ability to field charge it is not compelling.
Just saying, guys...
I'm sure you are right about everything, but I went the other way for a few reasons.
