Nexus 7 tablet
Finland
Do you know, will the Nexus 7 (2012) support DJI Pilot? I know, Nexus 7 II (2013) will support.
Maybe ask in the inspire forum if any owners are using that tab as its the same app.Rheumy should know
I have the Nexus 7 (2012) working with DJI Pilot. It took a few steps but so far (only a couple of flights) it is working well. Reply back and I will detail the steps followed.
Here are the steps to get the Nexus 7 (2012) (and I suspect many other tablets can be made to work) to run DJI Pilot
  1. I would recommend upgrading Android to the latest version Lollipop (currently 5.1).
  2. Root the device - I think there are a number of methods, I used WugFresh. Follow the instructions carefully and it should work with no issues.
  3. Install an application called Market Helper. This application does not appear to be on Google play and I had to download and install it from the site. There are detailed directions. This application allows any android device to appear as another android device to Google play. Ideally it would have had Nexus 7 (2013) as an option but I did not see it so I just selected a Samsung Galaxy S5.
  4. Once the Google Play thinks your device is valid for the DJI Pilot application, you can use Google Play to download and install it.
  5. So far it seems to run well but I can't say I have used it extensively, just a few flights with a Phantom 3 Pro.
Good Luck and let us know how it goes.
Hey, thanks a lot for the steps.
I got a rooted Nexus 7 2012 but I can't get it connected to the RC.
Do you know the Nexus 2012 is still working these days?
mpower
