Newbie question.
Poznan/Stargard Szcz. POLAND
I could not find on any threads any answers on that as I don't know how in technical language it called.
I would like to get rid of this "circular shape video " and have some questions regarding that if somebody would like to explain
1. What is the name ( technical ) of Video presented when Horizont is how to say , in arc shape
2. Is it any chance by any program to get rid of that effect
3. What is the reason of that , why cameras records that way ?
4. Same with the photos, can any program is able to change that ?
Many thanks in advance for any help
AnselA said:
Ansel, I installed mentioned program and now I know : It is called FISHEYE effect. Thanks.
I did few tests but I missing my FC2000 camera profile. Using any others like GoPRO, Cannon and others See a little picture /video disorted . After full export from program I still see a little worst quality. I don't want to use Stabilization function because it is even worst. Waiting finally for some gimbal and then I can start playing with that
- Did you created new profile or using only from list?
Regards,
Marek.
mchrol said:
I did few tests but I missing my FC2000 camera profile...
FC2000?
FC200 is in menu as a "standard" profile
FC2000?
Many thanks but I don't have it. My verion 1.0.66 64bit .
There is a option to safe profile. Would you do this for me ?
[email protected]
mchrol said:
FC2000?
[email protected]
I have ProDrenalin V1.067 64 bit. Did you scroll down the profile menu?
you can remove the fisheye in adobe premiere at has a 30day free trial, its under video effects etc, If you do go for the trial wait until you have a load of footage to correct as its not cheap. also research how to use it before , there's loads of you tube vids to teach you.
It is called fisheye. Go on youtube and there are many videos on how to remove fisheye effect from video depending on what software you have.
The technical term is actually Barrel Distortion, which is quite common with all wide and super wide angle lenses.
..tho as mentioned, its commonly referred to as Fisheye.
ctlfreak
