? needed to power a 5V front strobe
Eugene, OR USA
As I wait for my ordered strobes to arrive:
http://www.flytron.com/rc-light-systems ... light.html
I know that to pull power off the main battery via a soldered line shared with the FPV-RX, I THINK I know that I need a BEC. The strobes draw 5V and 50mA. I THINK I know that I need a BEC to drop/regulate voltage (AND turn off circuit selectively in low voltage situation?)
Can someone tell me exactly WHAT or WHICH BEC to order....or point out my misinformation.
Since I am NOT using the (BEC protected?) 5V line available from the Tarot gimbal to power the GoPro...I assume that is also one of my options?
Thanks.
5V line available
Thanks.
Here you go: http://www.hobbyking.com/hobbyking/stor ... ction.html
Sac,
Thanks. Just what I asked for.
The 7.5 gms weight of the BEC and the weight of the 4-5 inches of wiring makes me start to re-think this even though the strobe itself only weighs 1.5 gms. A replaceable, self-contained strobe/battery, or using the 5V line meant for the GPH3 starts to look better, weight-wise.
Sac,
That's why I suggested the Blue Arrow at 1.4 grams with 1A rating which should be plenty for your setup.
DonT
