Need Some Expert Advice (No Camera)
Hi Friends, I'm going through masses of stress just now due to my P3P and inability to get it to connect to the DJI Go app. I can not get a solution at all. :(
I've not used it since August and at the time it was the Pilot app. I decided to go take some footage of a Scottish location last week and was confused that it was now a new app name. Anyway, it would not show me camera mode.
I've since read up on all the updates of Firmware - which I've done - but can not update the RC as I do not get passed "How To Connect" for the App. If I plug the RC into the gimble it does not update, nether does a flash pen work.
I've tried the Samsung debugging setting, all manner of ways to boot up each device and nothing. I was so desperate I even bought a iPad Mini 2 and just wasted over £200 as it does not work on that either.
The RC can move the craft camera and the motors - without the props on of course - so seems to be able to connect with the craft, just not the App.
I've now discovered I've lost the recipe for it - although was bought on credit card - and DJI Europe want this for warranty. They want it sent in but have not said what is wrong.
How can it work on the old App just week ago and not be working now.
My fear now is that I've just blown £1400 as I've no clue what to do next. Any pointers, advice or likewise would be greatly appreciated.
Thank you in advance! ;)
Have you tried uninstall the Go app and reinstalling it? Have you tried a different cable from the controller to the device?
Reactions: Scottish Ryan
Hi bbfpv, thank you for replying.
Yes I tried two different USB cables with the Samsung Android Tablet and the new cable with the iPad Mini 2. I removed the app on the Android tablet too - even hard reset the whole thing - and reinstalled it and still nothing. I've toggled the Debugging mode and no pop ups or anything. The USB must be working as it looks like it's charging the tablet from RC.
On an Android device, go into apps and clear the data and cache. Delete the app and reinstall.
Hi Tcope, I did a full hard reset on it and then reinstalled it. You think I should do this too and see what happens in addition? I'm open to everything the now as this is crazy stuff! Thanks massively too!
Last suggestion I have. Downgrade to FW 1.4 then upgrade to 1.5.
Thank you, I do appreciate it! I tired to do that and the log file said...
========== 2015.12.16 08:30:49 =====================
Packet: P3X_FW_V01.04.0010.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
I will try again though, I've nothing to lose really!
Result: Abort.
Please post your log file
Is there any place to login? What happens if you press "how to connect". Problem might be that you're not logged in.
Yes, log in with DJI account (me part) but this makes no difference. I've just logged into it again and tried. Just tells me how to connect to app, I do the steps, but does not change to enter camera. I can get into with my OSMO on my phone DJ I Go app but not the P3P :(
What is the date you started having problems?
The last time I had it working was 17th August flight I done, this was using the DJ Pilot App. Decided to go out filming the other week and noticed it was now DJI Go and it's never worked with it. So somewhere between this App upgrade it's stopped working. I then decided to read up and take action, downloaded the Firmware yesterday, been at it constantly since.
I don't see any updates around that date or problems showing after updates. Just an excessive attempts at upgrading firmware when you first got it. I suspect the the RC usb module is bad.
Thanks Guys!
I started DJI GO on my Samsung Mobile - I use this for the OSMO - and it gave me the option to enter camera mode for the craft. So I hooked it up and entered, it just says disconnected in it, I tried the calibrate RC sticks and it said it was disconnected, even though it was plugged into the phone. Is this the USB module then? You can hear it in the tablet and phone - then shows as if charging battery - when you plug in the USB, this is why I thought it was fine.
Need to sleep on this for now. Massive thank you for helping here! I will approach it with freshness tomorrow hopefully.
Reactions: bobmyers
jadabyanza24
