BenDronePilot said:themosttoys said:007trains said:Just like to show everyone my latest setup:
On the phantom there are two 5.8ghz pentalobe antennas for the rc control and two 2.4ghz pentalobe antennas for the camera.
On the controller is a 5.8ghz parasitic helical antenna with a 1w booster and a 2.4ghz parasitic helical with a 2w booster.
With this setup i've gone to a range of 4.8km at an altitude of 50m so i'm very happy with the results.
Good effort. Post the video of the full flight with full pan / yaw at 4.8km. No offence, but I know for a fact that with your antennas orientated like that (horizontal), at far less than 4.8km (regardless of amplification) when you turn sideways (pan / yaw with the antenna nulls pointed toward home) you will lose wifi signal. Of course, just to fly straight out and straight back (with LOS), your setup will work fine.
Happy flying
You're right, I tried his exact same horizontal setup, in addition to pointing down, and defiantly found pointing down to be more reliable.
Hi Bendronepilot
did you manage to clarify if the repeater is diversity or MIMO? You may remeber I was convinced that it was MIMO but you thought diversity ?
