Model number of Phantom 4 RTK SDK controller?
Hello, could someone please tell me the model number of the Phantom 4 RTK compatible SDK controller? Could I link the GL300L belonging to a P4Pv2 to a P4RTK? What SDK controllers are you using with your P4RTK? Many greetings!
Reactions: G & K
Hi All,
I’m also trying to sort out the SDK compatible remote controller model numbers for the P4 RTK , currently I have the screen model one and apparently I need the SDK remote to set it up onto my Drone Harmony account.
Thanks in advance 😊
Reactions: Zostra Marina
Just ran into this. The GL300L is the model, but it must be factory loaded with the firmware. The difference is a little logo on the front. I now have a spare controller I can’t use with my 4PM. See attached
Someone correct me if I am wrong.
Hi all, thanks for the reply and yes, I can confirm now, too. A GL300L belonging to P4Pv2 is not compatible with a enterprise product like the P4RTK. It is confusing, because DJI uses the same model name (GL300L) in both cases... But only a GL300L that was bought together with a P4RTK or is specifically built for that (and has the little logo mentioned in L D&Ds post), will be compatible. I am using now a GL300L controller belonging to a P4M with the P4RTK. That works even tough in the release notes of the GL300L firmware updates it says that this is not possible (see picture attached).
I think DJI really made a mess regarding controller compatibility or at least is failing to provide clear information about that.
Many greetings and thanks again!
Reactions: G & K
Thanks for your time, it’s amazing how little knowledge the suppliers have 🤪
subject: Phantom 4 rtk supported rc name.
Hello Sir,
phantom 4:rtk supported remote controller names tell me all the names I will be very helpful if you get the model numbers.
Sincerely yours
tanvir
