There have been issues reported with Here (the new DJI map vendor) not properly caching satellite map imagery (although street detail seems to work.) I don't know if the problem has been fixed yet.Mine is not doing that or I have a setting wrong. I get maps with detail at home on wifi, I move the map around to look at other areas, but when i go out in the field, withouit wifi on built in p4p+ I get only lo res green blobs.
How do I make my iphone into a hot spot? If you please.
B&HWhere did you order it from? I thought about doing this too so I can use my 9.7" iPad (which I bought after buying the P4P+)
ThanksGo to SETTINGS on your iPhone. The 5th choice down the list is Personal Hotspot. Go into that and turn it on. Below the slider that turns it on is the Password you will need to enter on the DJI Android device when you select your phone Wifi. My Wifi says "Mark's iPhone"
