Loosing altitude
Hi first time Phantom Pilot,
I'm having problems with the aircraft slowly loosing altitude, can anyone tell me how to fix this ???
Or what i should calibrate to fix this ?
Thanks
Verl Speer
Check your throttle stick calibration and battery health first. Most likely bird thinks that centered throttle is bit lower.
Battery almost certainly has nothing to do with his issue and calibration is unlikely.
Is the reported altitufe lower than actual as the flight progresses (ie says AC is at 20m when actual is 10m) or is it actually dropping?
There is a barometer in the UAV that is used to maintain altitude. Perhaps yours is going bad and needs replacement. Sounds like you are in DJI Customer Service land. Good luck.
First time in ATTI yesterday..20ft high let it go down wind all by it self.
Then right stick to he left bring it back.From 20 ft to 10ft if I keep going
It will go into the ground,but still reads 20ft
Utica
