Looking for a good hi-gain antenna for my P3 SE
Any suggestions? I have tried a windsurfer and it is marginal at best.
Reactions: JoBe
Yes - as Oso points out, this is the wrong forum for the SE.
A windsurfer won't work on the SE because that stick antenna only communicates with your mobile device. The antennas that communicate with the AC are hidden inside your controller.
You need to do a mod to bring those antennas outside the controller via a cable. Then, you have quite a few options and no easy decision. It's complicated because your controller freqs can be changed between 2.4 ghz and 5.8 ghz. And most antennas work best at one freq or the other.
If it was me, I'd probably use either the ITELITE DBS (good) or the ITELITE MAXXRANGE (best). Know that these are 2.4 ghz antennas which means they won't work well if you try to switch to 5.8 ghz. Make sure you have the correct mount and correct cable lengths.
Good luck.
Reactions: JoBe and Plbjr
thedrinklabsus
