Look at my bad luck .. and a warning to other users
What i should do?
  • Try to Repair buyng the Flat cable and part of camera
    Votes: 2 66.7%
  • a new Gimbal
    Votes: 1 33.3%
  • Another
    Votes: 0 0.0%
  • Total voters
I was flying with my p3 pro .. All regular p3 , I had already passed the 7 minutes of flight when I returned the p3 close to me .. and was about to land .. I use these prop guards in image1 .. the small wire released Propellers and wrapped in what he did lose control and fall .. as you see in the picture .. I thought of buying the flat cable and see if it would fix the camera as part .. think hard ... well...
which suggestion you think I should I do? Thanks for attention!
Yes my friend..
the protective wire that is in the middle loose and held at Propellers ... not ironic ? :<<<!
I'm a Little confuse about the wire you're talking about I myself are using the same prop and never had a problem but am sorry to hear what happen to you this is my second P3 and my first one didn't have the prop on it but wish I did I did an update and it was out of control tapped a building and you know the rest but if I had the props I mite have been able to save it
It would have probably saved it.
Went the 1st way
No affiliation with this seller, I think he has the two spare parts you need
I'm waiting for a ribbon cable to fix my similar situation
Using this page as a guide
Lucas_rc_pilot
