Litchi Waypoints Questions
I just got finished doing a little practice shoot using the Litchi waypoint system. I have some questions to try and make things run a bit smoother.
My biggest concern was when flying to a waypoint that had a Focus POI set for it. If it's set at -15 for the POI, but the waypoint before it doesn't have a POI, it kind of snaps to the -15 quite quickly. I'd be flying along at around -45, and as soon as it reaches the waypoint with the Focus POI, it snaps to -15. It's not a smooth transition.
I can't really set the waypoint before it to have the same Focus POI so that it's smoother, because it's either around a corner, or I want it to be focused more so on the ground with that -45 gimbal. But like I said, the snap to the -15 is quite abrupt.
My other problem was that when I was out, I wanted to adjust the waypoints after seeing how they flew the first time. Sometimes I could put my finger on the waypoint and it would allow me to move it, but for a good 15 minutes, it wasn't letting me. I went on flying, then tried it on another mission later, and it was working again. But I sat trying to adjust waypoints for awhile and it wasn't working. I could click them to change the altitude, heading, etc. But couldn't move their physical location.
My wife thought I might have accidentally changed a setting that locked them, but I don't think so. Especially because it started working again later on a different mission.
Finally, this is just a hope, but is there a way, when re-flying a mission, to get the drone to return to waypoint 1 by going backwards through the other waypoints? So it flies it 1 through 5, then when I want to fly it again, it will take its original path back 5 through 1? Sometimes my missions are flown to avoid trees, and if I want to fly a mission a second time, I have to manually fly it back. It's not a big problem, it'd just be a lot easier if there was a function that would let me do the previous mission in reverse.
Thanks in advance for any help that can be offered.
Jerry P
