Litchi Reverse?
New Jersey
I have a mission set up that I usually fly in the morning with sun behind the bird. If I want to run that mission in the afternoon sun will be in front of bird. Is there an easy way to simply reverse the mission and do it in reverse?
Thanks
I think you're really asking more about reverse bird orientation for the sake of direction of the camera filming the same poi's? If so, a couple things.
Assuming you have no poi's and just want the bird to face away from the sun, you could go into each waypoint and manually change the heading to face the bird whichever way you want. You'll see the bird icon change direction in real time on the map to show your changes. Be sure to save your changes
If you have poi's that you wish to film, it's more complicated and you're best to just make a second mission for the afternoon.
Doesn't Litchi have 'Reverse' as an end-of-mission option?
:rolleyes:
rockymountaincaptures
