Litchi Question
Looking for comments from those flying the P3S using Litchi. Have you experienced loss of connection during waypoints mission and did the AC continue on the mission or what behavior did you encounter?
From what I've read, it depends on whether u're running it on iOS or Android. Apparently the two versions are not equally robust. Again, this is only my impression from reading multiple posts as I have yet to take the plunge and get it.
Litchi uploads the flight parameters to the Phantom and it flies the mission autonomously.
If you have contact, you get to see telemetry and follow its prograss.
If you don't have signal the mission continues as programmed.
Hi Meta, is your comment based on actual behavior you have witnessed or is that what Litchi states in their documentation??
canadiansauna
