Lastest Updates
Hi Guys
I've not flown my bird (P4) since August, I'm sure there have been some updates since then. My DJI Go version is 4.1.2. Is there some pros and cons for the latest updates I should know before before I do this.. Thanks
if I were you I wouldn't be in a rush to update anything... first go into settings>about and write down the current versions of everything - AC RC etc... then do plenty of research here.
if it was flying fine in August chances are it still will.
Dunno if the NFZ update is mandatory since then. Some newer GO you have to take a 10 question test (It's pretty easy and you cannot fail as it forces the correct answer.).
Thanks guys, and Uman it was flying just fine the the last time I took it up. And real good idea to check all the current versions
Hi Guys
What firmware you have?
Supercell
