Landing Shaking
If you had the VPS turned on, that would make sense. The area that is shown is too "disturbed" for the sensors to react properly. Try it again with the VPS turned off. My guess is you wont see that.
Visual Positioning Sensors....they are on the bottom of the AC. If these are on, and the landing area is not "uniform" it will cause very unstable landings. Personally, I never use VPS. You can turn them on and off in the app.
Mine does the same squeal on landing since the .700 update. I thought it was a bearing going out, but seems it's a firmware bug. Some report it shaking a lot too when throttling down and fearing ti will crack an arm.
I did a factory reset on everything and refreshed the firmware on everything. I also turned off the vps. I will try and fly later to see if that fixed it.
rockymountaincaptures
