Landing Mavic Mini
Eu estava tentando suavizar ou poupar o Mavic Mini, desmontei um helicóptero danificado, usei o trem de pouso e cole até o final, ou o resultado foi bom, não atrapalhei ou voei e aterrei suavemente, com uma boa altura a partir do solo.
O que outras pessoas estão dizendohttps://youtu.be/1pmh8QhUn6I
Very good. Do you need to be registered, because of the weight increase?
when I bought it, I already registered with ANAC (National Civil Aviation Agency) (regulatory body in Brazil) for prevention, but the increase was only 9 grams, going to 258 g. Best Regards from Brazil.
Reactions: WV. Rootman
I believe if all you fly is a Mavic you should also join our sister site ...MavicPilots..as there is a wealth of info there.
Check it out a link is at the bottom of the page to all 15 of
our forums.
dc
our forums.
dc
Thanks, I’m registered in Mavic Pilots too. ?
Great. Is a good forum. Post here all you like but if you
would please do post in the correct section as it saves me time moving threads on other DJI drones to this section i
just moved this to.
Thanks and fly safe and stay safe.??
