It can't Be?? 128g Micro Sd card Working!? Update 256g working !
This is Phantom 3 Standard Only !!
Working card list...
So,
What works?? What does NOT!!
What Micro Sd cards do you use in your P3S??
Please List all Sd cards that you have tried in your P3S...
Please be clear on what worked and what did not
P3S only, please!!!
The P3P can use many more Brands of cards??
So please let Us not confuse them...
Working card list
Kinakailangan ang Pagtiyak sa Seguridad < this is a link to my post :) Thanks!! Merle Tippy!!!
Screenshot of an email I received from DJI asking for a list of compatible cards for a Phantom 3 Standard:
I asked for a list of larger ones and the reply I got was that they don't have a list of recommended larger ones...
But I'm ok with that because I prefer to use a card that has enough capacity to last the length of one battery only, and change it every flight.
That way I never lose more than one flight's worth of footage if anything should ever go wrong.
I use the Lexar 633x, first one on the list, I have four of them and have never had an issue.
I know it was asked to comment on P3S only but P3A and particularly P3P recording 4k would have tighter tolerances in speed.
A SanDisk Ultra is class 10 compliant but I have one 64GB that eventually acted flaky in my P3 but appears to work OK in my tablet and PC.
Whether a larger SD card works or not depends on software code accounting for the larger size either by larger FAT table or larger cluster size. If you fill it up successfully without any contents getting corrupted then the software can handle the size. That's pretty much an all or nothing issue. Any corruption here and there is probably storage and controller quality being able to handle the speed and not due to size limitations.
Even though a larger card such as 128GB may work, you may be better off with more smaller cards. If one goes bad, you aren't out all the recordings you only had on that card or stuck with nothing to do more flights with. There's something to be said about changing cards on each flight too. If you lose the card during a flight, you're only out that session and not everything you've done up to that point.
Not 128GB but a Samsung 64GB 80MB/s EVO Select works fine in my P3S doing both video and pictures.
Picked one up on Amazon for $20
WOW, 256!! That's like a lifetime P3S card??? No need for file deletion!!! LOL
But Ya, That 9999 and 99:59 is normal...
It won't read correctly until it drops below that range...
