Is this works??? Pls help
i was planning to salvage my phantom my brother handed me a gift xaircraft650pro kit,,,wow its big. but wow I'm not expert at the moment...so i was planning to move the naza,gps,distribution board but will change the dji esc to 20 or 30??amps?? and solder it the rest will be this set up...
- TMotor Navigator 3110 780KV (http://www.addictiverc.com)
- RCTimer 11x5 carbon props (http://uavobjects.com)
-Turnigy Nano Tech 3300mAh 3S 35-70C LiPo
is it possible?? any help would be appreciated...
I don't see the reason why won't this work.
When install the GPS, since you will not have the dome right on the very top of the NAZA you have to enter the proper coordinate (X,Y &Z) with respect to the GPS location and the CG.
Also very important, if you choose to use Phantom TX, the antenna must be installed "vertical" and below the NAZA about 3-4 inches ( I am not positive about the number, you must recheck).
Good luck
Thanks mate i will give a try wish me luck. Il post pictures if this is succesfull if not then il still post picture but in the shelves lol...
Don carlos
