is this is normal behavior ?
CunningStuntFlyer said:
#1. GPS mode won't hold the Phantom in an exact spot.
#2. You're using the Gopro Wifi app to control the GoPro which is going to seriously mess with the TX. Please read the manual and then post again.
#3. Do an advanced calibration of the IMU, recalibrate the compass to get rid of the toilet bowl effect and turn off the wifi on your GoPro.
1, How much it will hold ? Is this is "bowl effect" ?
2, WiFi is OFF (i used to fly with WiFi ON, but after reading about "fly-aways" i stopped using it)
3, Yes, i did manual calibration and also advanced calibration. I also checked all values and all of them are in the range
Only im worry about is "cracked" GPS sensor. I ordered 2 spare ones and soonest they come, ill pop the shell and look, if that's the issue.
Any more suggestions ?
Is your Phantom behave same way ?
Thx
Wifi is on based upon the video you posted.
Yes, its OSD from GoPro and shows symbol WiFi but you cant see OFF right next to it. For some reason, its stretched over the visible border
So yes, WiFi was OFF
I use 5.8Ghz FPV with OS Mini OSD.
ideaForge
