iOSD mini problem
I installed a FPV system today on my Phantom 2 with the iOSD mini included. All of the video seems to work fine, including the symbols and abbreviations from the iOSD. However, it doesn't seem to be transmitting any numbers or actual information????
I don't have mine hooked up yet, but I might suggest checking the CAN-Bus connection, the cable between the iOSD and the connector on the leg. Then also check the ribbon cable to CAN-Bus connector on the leg.
Again, not really knowing, perhaps the CAN-Bus connection is loose inside the shell.
Also did you perform the updates to ALL of the components? The Phantom, iOSD, controller, etc., etc?
Hopefully, some one will stop by with a more conclusive answer.
