IOC doesn't work
Ukiah, CA
Just got my new Phantom V1.1.1 and can not get the IOC to function. I go into the naza assistant software and check the box for it as well as move the toggle switch on the transmitter which show it is working. But when flying I can not get it to work.
Don't know what to do now.
I did use the home lock and was over 30 feet.
In the software the switch is all the way down. Would you start off with that switch down or in the off position?
In the off position. Does the switch respond in the software...when you move it on the controller do you see the indicator in the program move as well?
For some reason when using the software and checking the operation it shows the right switch in the down position for the IOC.
I did get it to work now but the right switch is only down one position not all the way down. Don't know if that is the way it is supposed to be or not but at least now I know how to use the IOC function.
Thanks for the reply's.
DonT
