Installed gimbal ribbon protector ???
Thats not right.
Have you fitted it on correct axis motor ?
Should be less than 1mm gap
Where did you get that ? Definitely doesn't look right
I'm guessing you went with a knockoff instead of the more expensive Killer RC one? I've read a lot of reports of this issue with the knockoffs. The gap in the Killer RC one is almost imperceptible.
Just checked mine and the clearance is .30mm.
Yep, that's a knock off. I went through the same thing from Amazon. Then I got the killer RC one, now it's perfect.
I couldn't find anyone that had a close up pic. Is there supposed to be this large of a gap?
185,
No, that is not right send it back. Uninstall it and send it back, it won't help at all. I think they put the wrong "bumper" on it or it was cut and tapped at the wrong length.
Jerry
Yeah we have carbon fibre at work..il just glue a strip onto the plate....not worth 47 dollars .what a ripoff
I have the same one, I just machined a little off the arm in my milling machine. You can do the same by using a file or sanding it off. Do a little then test fit.
Thanks everyone.
I just requested a return.
I'll probably try and make it fit better though.
Should it actually touch each other or just enough to give some free play?
Thanks everyone.
185,
It shouldn't touch, just short of touching.
Jerry
I ordered the Hobby-Ace one from Amazon for $21.00 ,what a waste of time that was. It's going back and a new one from RC Killer is on the way.
