Inside a P3 Pro. Yet another broken cable repair.
Discussion in 'Pro/Adv Discussion' started by Multicoptertec, May 27, 2016.
  1. Multicoptertec
    Apollo Beach, Florida
    [​IMG]
  2. flpholt
    palm harbor florida
    someone is busy
  3. Pheonix7
    Any good pointers for opening the shell without bending the edges? My last opening was a total shell changeout so I wasn't worried about marking it up, but any tips would be great I if I decided to mod my P3A. What cable broke btw?
  4. Multicoptertec
    The 8 pin cable to the gimbal. As far as the shell, after removing the required screws, I use those blue cell phone tools to wedge along the edges of the arms. These tools are perfect, as they pull against the top half, while pushing in the bottom half. Once the snaps pop, I use wooden sticks between the top and bottom shells to keep them from snapping back together, while moving them towards the center of the bird to create constant tension for the next snap set. Leave the snap above the battery housing for last. When the two shells separate, you can then wedge the GPS connector out, and you're done.
  5. flpholt
    palm harbor florida
    how hard is it to take shell apart I am having problem with lights want to solder them so they work better
  6. Pheonix7
    It's not too bad. It's just getting those clips loose that can be annoying. I am definitely going to use the cell phone repair tools next time. Thanks for the tip.
  7. Multicoptertec
    Which copter Paul?
  8. flpholt
    palm harbor florida
    my standard
  9. Multicoptertec
    It's not very difficult, just a pain in the @ss. I have a soldering iron.
  10. flpholt
    palm harbor florida
    ill bring it and let you see what is going on
Similar Threads - Inside Pro Yet Forum Date
Screws size for "Quick release" prop guards P3S (photos inside) Standard Feb 9, 2017
Professional Sensors problems (possible iron particles inside the P3?) Phantom 3 Help Jan 15, 2016
NEW Product: Drone Crates Phantom 3 Backpack (Discount Inside) Pro/Adv Discussion Aug 3, 2015
Introducing the Drone World P3 Pro Upgrade Kit (discount inside) Pro/Adv Discussion Jul 31, 2015
Projected UAS Market (Business Insider) General Discussion Sep 23, 2014
