- Joined
- May 26, 2017
- Messages
- 14
- Reaction score
- 1
- Age
- 41
I have motors, esc, reciver connected with no shorts it has synced but it's not moving with commands from RC . I do not know where to go from there please help!!!
Is that with naza assistant? If so i just was exploring it dont really know how to calibrate properly yet.Have you done a stick calibration?
I think you may have the wrong section?Is that with naza assistant? If so i just was exploring it dont really know how to calibrate properly yet.
Thank you so much for replying.
What is an f550? Is that something with the Pro or Advanced?I have motors, esc, reciver connected with no shorts it has synced but it's not moving with commands from RC . I do not know where to go from there please help!!!
This is the Phantom 3 Adv and Pro section?please explain?
So f550 is not even related to the PHANTOM at all? Geez.This is the Phantom 3 Adv and Pro section?
no its is a custome build flame wheel f550 with lightbridge naza m v2 moduel , Zenmuse h43d, isod mini,BTU,CanHub,RC DT7&DR16 reciver with retractable landing gear.This is the Phantom 3 Adv and Pro section?
no its a custom frame you build on your own and make it your own with whatever components you want with it.What is an f550? Is that something with the Pro or Advanced?
its calle flamewheel F550 it is a heaxocopter made by DJIno its a custom frame you build on your own and make it your own with whatever components you want with it.
Ok. So why are you posting in the DJI Phantom forum?its calle flamewheel F550 it is a heaxocopter made by DJI
because there nospecific forums for dji f550 and usually DJI drone enthuiests own more then just the phantom 3. and have knowledge on the subejct i need help in. Im surprised you didnt even know the flamewheel f550 existed so im assuming you would be of no help. But you should look into it . Have a wonderful day!!!!Ok. So why are you posting in the DJI Phantom forum?
Because lots of DJI users have both. Worth a shot.Ok. So why are you posting in the DJI Phantom forum?
Wow! I'm soooo sorry. Judging by the vast number of responses and help you've recieved here, obviously I must be one of the very few P3 owners that doesn't own an F550 too...because there nospecific forums for dji f550 and usually DJI drone enthuiests own more then just the phantom 3. and have knowledge on the subejct i need help in. Im surprised you didnt even know the flamewheel f550 existed so im assuming you would be of no help. But you should look into it . Have a wonderful day!!!!
thank you my thoughts exacylyBecause lots of DJI users have both. Worth a shot.
I have a F550 its superb 1.5km range with video just at this too - the Orig Ground Station I also have on this is way better than the one for the PS3.obviously I must be one of the very few P3 owners that doesn't own an F550 too
I take you checked the motors are each running the correct directions for a "hex" ? - what do you mean by its not moving?it has synced but it's not moving
i actually have runn into another problem I recently bought the flamewheel F550 with Naza M V2, isod mini. CAN HUB, zenmuse h4-3D , DT7&DR16, retractable landing gear. I built the drone to the point everything was assembled to where I can plug in the aircraft to my pc to configure the drone threw Naza mv2 assistant program. I couldn't bind my transmitter with it so i asked for help threw Dji forums and found windows 10 doesn't read the coms port so I follows instructions and it worked for about a week then now every time I try to connect the aircraft to the PC THIS COMES UP and I do. Or know what to do. I have another flamewheel with Naza light and it works perfectly fine. I feel like it the fight controller or LED USB PORT . But I purchased a brand new LED AND IT STILL DOESNT work.It says "unknown USB device" " (Device Descriptor Request Failed)" Everytime I plug the aircraft to PC .I take you checked the motors are each running the correct directions for a "hex" ? - what do you mean by its not moving?
