How to tell a p4p camera from a p4
I’ve got a couple of cameras one i know is a p4p and other is a p4 question is are they interchangeable and second how do I know which one is which?
P4 camera on the left, P4Pro on the right.
If there are any parts that are interchangeable, I’m not aware.
The most notable outside appearance is the size. P4 is smaller.
F/2.8 94 degree Field of view for the P4
1:2. 8-11 24mm on the P4Pro
P4P is completely different camera and can't figured out why should be interchanged.
It is impossible at least I think that.
Since I repair these cams all the time, Starz gave a good visual difference and the others become visible after it is removed from the drone body. The Pro has one wide, flat ribbon connector & the Std. has 2 connectors, one narrow flat ribbon & one 4-wire, short power connector. There are several other differences between the 2 cams that make most aluminum parts not interchangeable, like yaw & roll arms. Yaw & roll motors are the same, pitch motors are different, but their drums are the same. Ribbon cables are different.
AlienzEyes
