Can anyone help me out. I have installed the IOSD mini and an immersion transmitter using the plug and play cable but the transmitter will not power up and the screen is blank?
Thanks
Tony
Thanks
Tony
Thanks for your reply, however I bought the cable already made up so this would not be an issueMatch up your cables to the VTX ports. Make sure your power, video and ground are in the correct spot. I have to move a couple wires to get mine working.
Tony
I can't see a way of swapping the cables over without cutting them off and soldering back on? The wires go straight into a plug connection?
Tony
Can you take a photo and show your wiring?Hi
Thanks for your detailed reply. Unfortunately still no luck. Could there possibly be a fault with the dji phantom 2 socket?
