Help with FPV order
I am using a stock phantom and a hero3+Black. I am shopping for a Fatshark dominator but am confused about exactly what accessories and additional parts i will require to get it working. Can anyone list the items needs in addition to the base Dominator?
Battery for the goggles? Cable to the Hero? Recommended video transmitter and receiver? Upgraded antennaes? Anything else? Lots of decisions with lots of confusion!
And if i decide to get some kind of a small LCD monitor to install on the phantom controller, can i use the same Dominator gear and simply add a small monitor and video cable from the goggles to the monitor? What else would I need to make that setup work?
Thanks alot!
Hi Adam
Yes you will need a Fatshark battery like this: http://www.firstpersonview.co.uk/batter ... ah-battery
A GoPro 3 to ImmersionRC transmitter cable like this: http://www.firstpersonview.co.uk/cables ... -out-cable
I'd recommend the 600mW ImmersionRC VTx: http://www.firstpersonview.co.uk/transm ... onrc-600mw
The receiver module is the Fat Shark Dominator Rx module here: http://www.firstpersonview.co.uk/receiv ... ghz-module
I'd say the ImmersionRC SpiroNET CP antenna were definitely worth the upgrade: http://www.firstpersonview.co.uk/antenn ... c-spironet
There's a bundle here that includes all of the above, and a couple of other bits (such as a balancer to JST lead for powering the VTx and camera): http://www.firstpersonview.co.uk/comple ... tor-system
All the best
Simon
tanglefoot
