Hello from Burpengary,Queensland,Australia
I have a P3P and programmed a mission for filming to start at my first way point after staying for 1 second,but it would not start automatically. I had to turn it on manually. Any reason for this.This is the second time it has happened.Thanks
Reactions: CPO Coastie
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching . ?
Welcome to Mavic Pilots from Dayton Ohio! If you are using Litchi make sure your path is set to straight lines not curves. If you curve the path at the waypoints the actions at each waypoint will not work. Fly safe and have fun!
