Handy Flight Map
Drone Map Format.
Make a Shapes Transparent in Microsoft Word:
1. Select Insert > Shapes.
2. Select a Shape from the drop-down gallery and then draw it the size that you want.
3. Right-click the shape and choose Format Shape.
4. In the dialog box, in the Fill section, select the Transparency slider and drag rightward to set the degree of transparency you want (100%).
5. Footpaths made with 'Shapes' (Curve) Format AutoShape for colour etc.
Google Earth Location.
Crop Map to 6X4, and Brighten.
Microsoft Word Paper size 12.2cm x 23cm.
ALL Margins 2.54cm.
Page Border 3pt.
Text White Size 10 Arial Bold.
Shapes Red 1.5pt.
Print and cut on dotted line.
Cut Photo Paper (to stiffen Zippy Bag) 12.2cm x 23cm.
DL/Travel Zippy Bag (301602) ebay fit small split ring in corner under zip for Lanyard/Loop for Belt Clip if needed.
* Below is an updated version of the Template
  • Drone Map Template.zip
  • Updated Drone Map Template.zip
Leary of downloading a zip file and loading on my puter..
What exactly is this?
Can you post a pic of it in your message?
All the zip file contains is a Microsoft Word Template that you can put a Google Earth capture on. It will be handy, (I think) for adding information for your intended flight area.
PS had Honda 150 Superdream and CX500.
Thanks Dave.
Spell check got my last msg. Corrected it. Are you able to post a pic of the template?
I.E. I drag and dropped this in this msg. Just a random pic of a controller I sold.
Hello CR125Honda,
The enclosed image is just a 'capture' sample to give you an idea of what is in the zip-file, just a Microsoft word document that can be altered on your PC to suit, and is made to fit in the Zippy Bag. I assure you it's safe to open.
Wouldn't let attach a document on it's own - had to be in a zip file for some reason.
P.S. Page border needs to 9pt not 3pt for cutting.
akos9703
