ground station for Phantom 1.1
I want to use ground station with my phantom 1.1 to do autonomous flights
I have naza 2.o OSID Mini and a zenmus 2d gimbal and storm FPV
what more do I need to add??
canbus Hub?
Bluetooth module??
I don't want to buy the wrong parts
Thanks
The blue tooth module comes with the kit. You need only buy the kit and can hub for extending canbus cable to G/S rx
cool thanks..
I am ordering it today :)
now I just need to figure out my mounting situation the case is crammed full as it is
You won't need the canbus hub. Just plug the groundstation in to the spare port on the side of the iOSD mini. Also, do you already have a PMU or canbus port on your Phantom?
got naza v2 plugged in to pmu then osid mini plugged in to the pmu and zenmuse plugged in to the mini.
the whole thing weights 1223 grams with 2800 battery
Ahh ok I was assuming you had the upgrade board. Without that you will need the canbus hub...but that's a bulky item to pack on board just for the sake of one more port. Have you considered installing the upgrade board? This would be a great time to do it, and it would let you lose the canbus hub and Zenmuse GCU...and even the PMU if you want.
robvalduga
