Gimbal lock (plastic) replacement
I just ordered one of these for my P4 Pro. The OEM from DJI keeps breaking at the leg connection. I'll report back after I use it for a while. Hopefully this will last longer than the OEM product.
I saw that one but wasn't sure if it would fit a Pro V2 ?
Gimbal/camera stabilizer is identIcal. . If you want to use the stock clear plastic guard without the frustration and fear of breakage, you need to use a file to remove some material inside the opening area where it snaps on.
I have a P4 Pro V2. I think the camera and gimbal are the same on V1 and V2 as per what I've read. If I am wrong, someone please correct me. The P4 Standard is different and not compatible.
Yep. Same size for Gimble lock
