Gimbal Dial Not Working
For some reason my camera has started pointing straight down and not responding to the dial on the controller. It did respond when I hit the gyro sync but still wanted to point straight down.
I was able to get the dial to work after messing with it for a while but I would have to move it very slightly and it is not responding as it should. (up was down and down was down and then up)
I have put in a new antenna and had the transmitter apart and now after it is back together the dial does not work at all. ( I might have put the plug in the wrong connector) Ill check that tonight but anyone have a solution for the slow/non responsive dial?
You should be good to go if you follow these instructions exactly:
cokersean20
