dronescostarica said:Hello everyone.
Does anyone knows if a weather collector data accessory exist for a DJI 2?![]()
Hello backatcha,
That's a great question. If you don't get a response here, I may post it elsewhere.
:shock:QuadcopterAcademy said:Do not mess with LiPo batteries. Throw them away. They can explode if you're not properly maintaining them!!!
Welcome to the forumPegramj said:I crashed my phantom vision 2 plus. I've tried replacing the broken gimbal ribbon wire. Each time I powered it up the cable would short and start burning. Any idea what the problem is?
Adam said:If it doesn't fit in the other forums, this is the place.
fantasma1 said:Adam said:If it doesn't fit in the other forums, this is the place.
Ok, I m new to this cool thing and obviously spending such amount of money and knowing or receiving a proper training is a risk, I flew my Quadcopter about 3 times. Every time I calibrated the accurate possible. Trying to lift up instead goes out of balance to the front and end crashing, what might be wrong?
All controls are normal settings nothing been changed.
Marlin009 said:fantasma1 said:Adam said:If it doesn't fit in the other forums, this is the place.
You should post this in another section or it will get lost in this thread.![]()
Find the section that fits the Phantom you have, Vision, Vision + etc. then provide as much info as possible. Is it new, used.....Lot's of folks here that can help you.
NinjSeba said:I just got this, http://www.uavdirect.com/product-p/fpvm7-ultra-sys.htm and I got not instructions, so far I have not found any videos pertaining to how to install this particular kit I got a lot of wire in the kit some are plug and play per se and some are ment to be soldered, this kit is not supposed to need soldering.. I just dont know what goes where. any ideas? The iosd Mini is the biggest mystery. like wtf does this all hook up to?
some of the connectors I got with this were these below
this actually came with the iosd mini
I hooked up the transmitter the way it said to, i opened the case, there was a wire connector and I unplugged it and replaced ut with the one that goes to the transmitter, so wtf does the iosd go??
This is from a different user. I just don't see a PM button anywhere on a member I have been talking to about an item. Can you elaborate as to where the PM button isClick the PM button on the left, right under the members name.
