Hi,
Installed a FPV combo on my P2 (HD 3D and Hero 3+)
Flysight 400mw 5.8Ghz A/V FPV Transmitter
DJI Innovations Phantom 2 FPV Cable & Hub
DJI Innovations iOSD Mini
Flysight Black Pearl 7" FPV Monitor with 5.8Ghz Receiver
DJI anti interference board
I'm getting the horizontal lines issue which is mentioned on this forum (power feed from P2 into Go Pro causing noise)
HOWEVER . . . . . on it's first flight, video feed was fine up until the P2 reached 82 metres altitude (about 40 metres down range), then it broke up and finally went altogether. If I reduced altitude, the feed came back. Orientation didn't have any significant effect. Recorded video footage was unaffected, it's just the live FPV feed to the BP.
The Tx and BP are running standard rubber duck aerials, but I was expecting more range than this, even on the standard setup. I've checked the Band and Channel settings between the BP and Tx are matched.
Anyone else running similar spec and getting greater range, or any suggestions as to what is wrong ?
Regards,
Simon
Regards,
Simon
