Firmware upgrade (v 1.9.60)
I'm guessing at some point you removed the .bin file from the SD card and then started up the Phantom again? If not, do so.
I've tried both methods, with and without .bin file in the sd card, but also redownloading the firmware and putting it in a freshly formatted sd card didn't start the upgrading process, my drone starts normally but without upgrading
I'm a little confused. The app reports everything is updated and the drone starts normally. What is the issue?
I'm confused too!
All seems to work well (not fly yet)
The problem is that when I upgraded to latest version the process ended with the steady Red gimbal light and the continous beep (that normally indicate the failure of the process)
If you had red gimbal LED at the end of the upgrade, the process was not complete. You should if possible downgrade and then upgrade again.
Red gimbal led also means that sd card is missing
I really don't know what happened, anyway here is my sdcard txt result:
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: P3S_FW_V01.06.0040.bin
Upgrading ...
Result: Success.
Packet: P3S_FW_V01.07.0060.bin
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:13 remo-con disconnect======
Packet: P3S_FW_V01.08.0080.bin
Upgrading ...
Result: Success.
Packet: P3S_FW_V01.09.0060.bin
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2014.01.01 00:00:11 remo-con disconnect======
Result: Abort.
Result: Abort.
I am also confused. Looks like it did update. What is the AC not doing correctly ? Take the SD card out and switch the controller on and then the AC - what does DJI app say in the top corner? Is it getting GPS ?
DonT
