Firmware update to 4.02 - PPM or D-BUS???
Hi..
After I updated the Firmware of my FC40, fist I couldnt control it, until I switched receiver type from PPM to D-BUS... Wich one should it be? The manual say PPM, but I cant get it to work in PPM only D-BUS..
Im really confused, and afraid to take it out for a flight now :O
Regards Nicolai
Oh perfect, for some reason i was sure about it was PPM! Been seaching the web for 2 hours :eek:
Just dont understand my Naza Assistant keeps telling me that there is an update even tho its the same i already Got :()
I had this update problem with my phantom too. It's not really an issue per say. I think it's just naza being pushy ;) on the update tab just make sure you do indeed have the same version installed as the latest version being offered. The power cycle your fc40 reconnect to the assistant and check again the version installed and then check the do not show me this again box on the reminder. Should not bother you anymore!
The PPM switch is used only if you're using a transmitter other than the one that was provided with your Phantom from DJI.
