Drone downunder
Hi got a problem with my Osmo Action, Batterie stuck, anyone could give me some idea how to get it out, the camera got hot when charging
Reactions: dronesky
Welcome to the forum I don't know about the Osmo battery but I'm sure someone does and will help you out good luck
Try using strong needle or pin instead of knife,,spring loaded release might be sticking or not fully pushing in
thanks, no luck, I might try drilling into "Osmo Action" Batterie and try
pulling it out with a screw attached, any thoughts about this!?
Don’t think I would drill into any battery .
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching. 👍
Reactions: dronesky
I wouldn't drill into it you might short out between 2 cells and start a fire
Reactions: dirkclod
A drill might end up 4th July firework, not recommended 😶‍🌫️
I would have someone push the centre battery release and you have mini screwdriver on each side and pri or lift it upward.or take it somewhere who could do this for you
