DJI Phantom 2 Carbon Fiber Adapter Mount Plate: Tarot T-2D v1/v2 & DYS gimbals
TAROT T-2D Brushless Gimbal (for Version 1 & Version 2 gimbals) & DYS 3-axis brushless gimbal for GoPro Hero 3 Conversion Adapter Bracket for the NEW DJI Phantom 2 Quadcopter
  • Lighter than some other all metal mounts, meaning increased flight times.
  • NEW design fits both new Tarot T-2D v2 (plastic) AND older v1 (carbon fiber) gimbals.
  • You can finally mount your V1 or V2 Tarot T-2D Gimbal on your new DJI Phantom 2 Quadcopter, without having to drill any holes in your shiny new Phantom 2
  • This bracket will also work on the DYS 3-axis brushless gimbal (seen here: DYS 3-axis brushless gimbal)
  • This bracket is made from super strong and lightweight 2.5mm carbon fiber and only weighs 9 grams!
  • Mounting bracket fits tight against the Phantom 2 fuselage with hidden screws, so no need to use extended landing gear or other modifications to raise up the Tarot T-2D gimbal
Screen Shot 2015-04-01 at 12.07.14.png Screen Shot 2015-04-01 at 12.16.17.png Screen Shot 2015-04-01 at 12.16.28.png Screen Shot 2015-04-01 at 12.16.34.png Screen Shot 2015-04-01 at 12.16.39.png Screen Shot 2015-04-01 at 12.15.07.png Screen Shot 2015-04-01 at 12.15.15.png
Includes:
  • 1 x 2.5mm Carbon Fiber Mounting Bracket to fit a Tarot T-2D v1/v2 and DYS 3-axis brushless gimbals to your DJI Phantom 2 quadcopter.
  • Optional: 8 x mounting screws, 2 x mounting bolts (please select at the top of the listing if you require them).
More detailed step-by-step installation instructions can be found here:
http://www.mpinder.com/design-proje...t-t-2d-v1-a-v2-gimbals-on-dji-phantom-2-.html
BUY HERE: http://www.ebay.co.uk/itm/131453417883
Need 10mm spacer risers for after you've mounted your Tarot T-2D Gimbal?
The most elegant way of extending the height of your DJI Phantom landing gear & no need to entirely replace your landing gear just to get some extra height.
  • Extend your landing gear without having to buy longer and wider gear, just add these extension spacers and raise up your Phantom by 10mm.
  • Works perfectly for Zenmuse, DYS or Tarot T-2D gimbals which require slightly higher landing gear to prevent the GoPro from touching the ground (see images above).
  • Phantom still fits perfectly inside Phantom backpacks for transportation.
  • Made from very strong ABS Plastic.
  • Precision 3D printed parts.
  • 3D printed at 25% density for lightweight strength.
  • Spacers only weigh 9grams!
Screen Shot 2015-04-01 at 11.39.33.png Screen Shot 2015-04-01 at 11.39.40.png
BUY HERE: http://www.ebay.co.uk/itm/131468861055
