Dji Iosd mini on Phantom 2
Just solder according to the iosd pinouts.
Is that what you were looking for? see attached image.
I already had that. I just don't know which wires are which on the transmitter. As seen in the photos on my last post, there are 2 wires and i'm not sure which to solder to which. Thanks for the help
Your transmitter has 2 ports on it, only the plug with the black+green wires coming from the same plug is used for vid connection. The black wire on that plug gets connected to the top wire in Leo's diagram above. However, according to the documentation of your Tx, the vid feed wire is yellow and not green, and that's what should be what connects to the 2nd wire in the iOSD diagram. I don't see a yellow wire on your Tx's plug, so I'm not sure what to tell you.
