Meta4
Premium Pilot
- Joined
- Jan 8, 2014
- Messages
- 15,355
- Reaction score
- 9,298
The early single channel receivers were clunky and near impossible to use with even light tree cover.My recollection from ancient times is that consumer grade units were single frequency devices, had limits on the number and quality of receivers, and generally took a very long time to lock in enough sats to compute position. In contrast, military units were dual frequency, and contained more receivers making them far more accurate. I also seem to recall that manufacturers were required to cripple devices as to altitude and velocity so they couldn't be used to pilot ballistic missiles.
Then on the satellite side SA caused the intentional streaming of errors to further reduce accuracy. So I think there were a multitude of factors in play though I agree that turning off SA was a big step in the right direction
The evolution of receivers advanced and Garmin brought out several 12 channel models from 1997, well ahead of the switching off of SA in May 2000.
The idea of manufacturers crippling devices is probably a myth as SA alone was more than enough to seriously upset precision .
When SA was switched off it was quite unexpected. It had been talked about as something that might happen in a few years and then one day it was just switched off and GPS suddenly was much more accurate..
