Controller Mod to connect to rooftop mounted Antennas?
Hello all,
Would anyone be able to provide a link showing how to open and mod the controller to be able to attach a lead going out and to a antenna that would be mounted on a rooftop?
The loss presented by the longer coax runs would far outweigh any benefit.
What is your intent. You would have to use a signal booster going that route. Also what are your needs for OSD and FPV?
He probably wants to sit on his couch and fly via FPV on his TV. That's usually the reasoning behind these types of questions in the past.
I was wondering if he might need help due to a disability.
I have access to 1/2" coaxial cabling, and have no problems with the booster, as t seems the ones with the specs I need are easily available on eBay.
More than anything I just want the added benefit of being able to place an antenna on a 20ft pole to be able to get a solid boost in range. I was also considering a smaller version for the car.
Did anyone notice their UAS trailer in the slide show?
These antenna mounts are using teflon coax which is an excellent choice for 5.8 GHz.
MS60
