Coming straight down from altitude
Discussion in 'Phantom 2 Vision + Discussion' started by johnbrowning, Jun 30, 2014.
  1. johnbrowning
    has anyone come straight down from altitude, with the stick all the way down, to see if there are problems?? I believe i read it's not recommended, but has anyone done it???
  2. ftimster
    Yep im on 1.08 and i can come down very quickly just not straight down keep moving!!
  3. Dirty Bird
    Glen Burnie, MD - USA
    I do it all the time with 3.0 firmware and I've never had a problem.
  4. Garysam
    Prior Lake Minnesota
    Phantom 2, version 3.0 at full stick do it all the time
  5. Major_Defeat
    North Canty, New Zealand.
    With the descent restrictions, I cannot get any other control other than straight down if I want to descend at 2 m/s.
    If I want to do any forward or sideways movement I have to reduce this to 1 m/s.
    So straight down it is, otherwise a flat battery will help me with a speedier descent. :shock:
  6. Garysam
    Yep same thing with me
  7. canerakcil
    Coming straight down speed is limited with the firmware update, but i don't understand why can't i come down at the same speed while going forward at the same time. It takes too much time.
    If you descend the craft straight down fast, it will make unstable movements but if you fly the craft to any direction while descending, it won't be affected..
    So i think straight down speed should be stay limited but flying and descending at the same time should be faster.
  8. tmc6663
    san diego, ca
  9. johnbrowning
    Thanks all for the replies!
    JB
  10. Phantom_Menace66
    Perth, Western Australia
    If you have NAZA mode enabled, flick the S1 switch to ATTI and you can descend as quick as you like.... However, if you descend straight down very quickly, be sure to release the left stick at least 20-30ft above the ground as it takes time for the Phantom to stop falling....
  11. rhino
    Australia
    And don't do it on a low battery.
    It won't have the power to slow the descent quick enough.
  12. kajunaviator
    I am new to the Phantom world, but I am a helicopter pilot and can tell you that it is not recommended to make a straight down descent in any type of rotor wing air raft. No matter what size aircraft, you can enter what is called ring state vortex. What happens is that the aircraft will begin to settle in it's own vortices and it will loose lift. That lose of lift if not intdrupted by forward flight will increase to the point that will make recovery impossible and the aircraft will literally fall from the sky. This is a very dangerous condition that we are taught in flight school to avoid at all costs.
  13. Wedeliver
    Tionesta, California
    On the FC40 with no gimbal it is easy to see the quad start to rock back and forth when descending. Although it rocks a bit it does not loose control or seem like it would crash or anything. When I go to some high elevation I bring it down by fully pushing the throttle to the bottom. All this Vortex Ring State talk is getting me scared and I am not moving forward and backwards while descending so I don't end up with a bad story to tell. In 1968 I flew a Huey gunship in Vietnam 2 times for 1 hour total, never heard about VRS back then or I forgot about it. There are a lot of pilots here who believe that they have crashed due to that event occuring. There is one video of a P2V crashing and it does not even seem to be descending. It is hard to tell how the quad is flying when the gimbal smooths out everything.
  14. kajunaviator
    The difference when at a higher altitude is that you have wind flowing across the aircraft. At the lower altitude, you don't have as much wind. The speed of the wind directly translates to the forward air speed of an aircraft with zero wind. Therefore if you have a 10 knot wind speed , it will help to counteract the rotor vortices. Hope this helps.
  15. kajunaviator
    Anyone interested can Google Ring State Vortex. You will probably find a better explanation than what I can give.
  16. kajunaviator
    I mix up my words. It is Vortex Ring State, also called settling with power. Hope this helps.
Similar Threads - Coming straight down Forum Date
60-Minutes "The Coming Swarm" News Today at 8:08 PM
Overcoming the Stigma of Drones General Discussion Monday at 9:37 PM
Big Changes Coming News Aug 7, 2017
Coming Home - A Bastos Movie Photos and Video Aug 7, 2017
Watch "New UK 'Drone' Legislation coming.." on YouTube General Discussion Jul 23, 2017
