changing the resolution?
How can i change the resolution - atm pics are taken with 4000x3000, that sucks. Im using the Android app.
4000 x 3000 is the max resolution. If the images are not as sharp as you expect, you can turn up the sharpness in the camera settings. They also sharpen up nicely with Photoshop or other computer software.
I have iOS, but probably the same for Android. Tap the camera settings icon (camera with a gear on it) near upper right. Then tap Image Size (currently set at 4:3). Then tap 16:9.
Reactions: Jan1983
I wanted a 16:9 res.... 4000x3000 wont fill the screen ;)
The best thing to do is crop after the fact. If you change the camera to 16:9 you'll get the same 4000 width with fewer horizontal pixels. In other words, that mode is a crop. If you crop it yourself in post, you'll be able to pick the best crop location and likely get better resulting photos.
Chris
cokersean20
