Change work frequency
Germany
Hello,
Is it possible to change the work frequency with the GoApp4 for Android?
I cannot change it. Nothing happens if i tap to the blue 5.8GHz button.
screenshot_20161224-153031-png.71567
Is this just an issue with the Android version or are there any settings i have to do?
Thanks for your help
If it's like for the inspire you need to have tablet/phone in specific region, for example with U.K. set can't change frequencies but for US think you can? Can switch between 5.8 and 2.4 fine though still
Looks similar to what happens to the P3Pro if your in Europe, you can get access to the ability to change transmission settings if you change your language / location in android to USA. Think its down to what frequencies can be used in what countries.
Hmm, if i change the language to US, i still cannot change between those two.
But now it's possible to choose the channel. This i couldn't before that either
Here are few photos of how it can be changed, perhaps iOS is different to other software?
Thanks Snow, iOS is definitly different to the Android menu.
Does anybody use here the P4 Pro with Android? I would be very pleased if someone can confirm that issue.
I use a Samsung Galaxy S6 Edge+, maybe someone uses the same setup?
Reactions: Snowwolf
Problem solved...
After downgrading the firmware and update again, the 2.4GHz are there.
Don't know what has been going on there but... It's software... That's all i have to say about that...:rolleyes:
Anyway thanks for your help guys.
Problem solved...
I have the same issue apparently... my 2.4 went away after upgrading :mad:
OK, downgraded firmware, still nothing, upgraded back, still nothing.... it's got to be the new version of the App.... is there an old version of the 4.0.0 app I can download somewhere?
src72
