Case For Ipad Mini 4?
Do you guys use a case for the ipad used for flying? My P4 control probably doesn't hold the iPad with a case too. What is everybody doing to protect the iPad?
I bought this from Amazon and it fits great and provides some drop protection (it does have a small lip on the front edge).
Reactions: tak5501
Before I purchased a sunshade that actually holds my mini 4, I used the genuine Apple silicone case + smart cover which worked perfect on the P4 controller.
I would just fold the smart cover over to the back side of the iPad and then install to the controller.
Not the cheapest case combo available but if you search you can usually find both halves for less than $50.00.
I use what DarkDrone is using, but I do remove the magnetic folding top cover as that reduces the pad thickness and helps the transmitter holder to get a better hold on the pad mini.
jeetbuzz360
