Carbon Fiber Props + 500M Range ?
Hey guys
I'm new to the forum, I've shot a few short clips and taken some nice pictures. My drone is the basic Phantom 3 as I thought It wouldn't be worth me forking out for a P4 and just crashing it on my first go.
Today I was flying and it begun to rain and as I was returning to my take off point as I came down I lost signal (Another question about this further down) and I managed to flip the **** thing. Main cause was my skill but also some uneven ground which I didn't calculate. So I ended up snapping the ends off 2 props. I've got some spares but I wanted to get another set (Just in case it happens again!) so I found these on ebay
4Pcs Carbon Fiber 9450 Propellers Self-Locking Blades For DJI Phantom 2 3 | eBay
Are these worth buying? It seems the regular white ones are cheaper but thought as they are CF they might be a bit stronger? Correct me if I'm wrong
My other question is I read that the P3S should be able to fly 1000m, But I can never reach more that 500m before I start to lose signal. I own a fair bit of land around my house and there are no other houses for up to a mile. Why is it only achieving half of what it was sold as?
TIA
Hey guys
TIA
In my opinion don't use carbon fiber props...buy OEM ones.
the P3S is not sold with a range of 1000 meters but you can get it to go much further. Just use the search for advice.
Phantom 3 Standard - Specs, FAQ, manual, video tutorials and DJI GO - DJI
8214 feet distance with a stock antenna and no modifications. Check you see tings in the Go app make sure max distance is off in app.
Reactions: Philltayl
Hey guys
TIA
"But I can never reach more that 500m before I start to lose signal." More detail, what happens? Errors? Bad image? No signal and RTH?
Also so you know DJI has CF props (so their OEM too). I just got some and have flown twice with them so far, makes the drone a bit more responsive, and maybe faster too. They might not be 100% CF, but reinforced with CF.
The way I see it is that true CF props are too ridged in flight. The bad news comes not when all is well but in the event of a mishap, CF is strong and doesn't absorb the energy involved in a strike, it will transmit that energy into the motors and more so into the mounts and arms resulting in expensive damage. :)
Reactions: sam-car
Exactly! In a minor crash, like a tip over, something has to give. I'd much rather a $5 prop break, than an arm and part of a motor or shaft.
What configuration are your antennas on the controller? Remember the transmission/reception is not thru the tips(null area) set your controller antennas like your giving your bird the Double BIRD... ;-))
Reactions: Pharm
I was replying to "pepperplant", he was the one with the range issue, not me. That first line was a quote.
hcashmore11
