Camera shade
Is there a shade that doesn't make the gimble drop?phantom 4 obsidian I have tried 3 none of them work.The one for my p4 works fine.Or does the gimble on my Obsidian have a problem?.I even calibrate it with the shade on but it doesn't help.Although that trick works with p3 And p4 standard..
Is there a shade that doesn't make the gimble drop?phantom 4 obsidian ................... I had same issue with my p4,,,my solution was trimming one up to suit..I did cut one clean in half aswell and used rubber band to secure it around cam lens,yes the old gimble not like these shades,once trimmed up the weight was better,:D,gosh you could probly make one out of light weight plastic any colour you want,these type of petal shades cheap but easy to make
I use a long lens 8.5mm, and gimbal twitch due to prop wash is a problem. This solves it it and make a nice shade.
Reactions: MotorCycle-Man
Johnboy94
